1998 Chevy Lumina Locating turning indicator fuse
102,000 MILES • 6 CYL • 2WD • AUTOMATIC
4LILPIGGYS
My Lumina has a problem with the turning indicator when I try to signal to go left. The flasher arrow ticks fast and sometimes the light (signal) does not flash. Other times it is fine. ? with other cars i have had it meant the flasher or fuse was bad. I cannot find the owners manual and am not sure where the box is and which fuse is the right one. HELP HELP !!!
Mar 21, 2010 at 3:53 AM
LEGITIMATE007
  • 5,121 POSTS
on this vehicle , the flasher fuse should be located under the dash , clipped to the steering column, it should be silver and round . look really good because for some reason chevy wanted to play hide and seek with it
Mar 22, 2010 at 2:52 PM
