1998 Chevy Lumina jerking
1998 CHEVROLET LUMINA
86,000 MILES • 6 CYL • FWD • AUTOMATIC
JAY_89
  • 5 POSTS
hi i have a chevy lumina 98 with 86000 miles on it
from last couple of weeksi am facing some problem with transmission
when the engine of my car is cool it runs fine but when the temperature reaches upto normal it jerks the first gear only and secondly when im driving at a constant speed like 50 mph and i want to go for more speed it changes the gear from 4th to 3rd than 3rd to 4th it happens for 1 or 2 secsthan it changes and if i am at 50 and i pump the gas harder it doesnt happens it only happens when you want to increase speed gradually
i took my car to 3 tranny specialists and all of them said there is no mechanical or electrical fault in my car
1 said change the whole tranny but if i dont know the exact problem how can i change the tranny
May 31, 2009 at 9:51 AM
BILLYMAC
  • 2,204 POSTS
Hi, there is a cable that goes to your throttlebody it is connected where your accellerator cable connects there is a lock that you push down to release so you can adjust this cable.
adjusting this cable actually adjust the throttlevalve pressure ,which adjust the shift pattern this cable should be checked for binding or fraying . other then that you can service the trans. new filter and fluid
good luck billymac
Jun 2, 2009 at 1:15 PM
JAY_89
  • 5 POSTS
thanks for the information but i guess i cant do that by my self howevere the transaxle oil is perfect, I dont know abt transmissiom filter,can you tell me how to check transmission filter
and if i want this work to be done do i have to take my car to a mechanic or transmission center ?
and onething more do the spark plugs have to do any thing with this ?? or coiltovers ??
thnx
Jun 2, 2009 at 2:34 PM
BILLYMAC
  • 2,204 POSTS
Hi if the fluid is clean and red filter is ok.
the coils or wires will cause jerking ,but usually not just in first gear.if you have old wires yes i would do a tune up. and any shop can adjust the throttlevalve cable and check it. good luck billymac
Jun 3, 2009 at 10:31 AM
JAY_89
  • 5 POSTS
thnx for you reply
couple of things more
how much will it cost me the throttle body thing
coz i dont want to spend 400 or 500 dollars on this car and secondly if i dont fix this prob for how long i can drive it
i changed my gas and now the prob is i guess 70% finished first it was happening quite often now it doesnt happens until you really want to do that ??
i got my car checked and coil towers have some white spot in them so is that mean its bad ??
Jun 3, 2009 at 10:54 AM
BILLYMAC
  • 2,204 POSTS
Hi if burnt spots on coils or white spots wires are bad. it should only cost a half hour labor to adjust cable. but if gas changed anything won,t be the trans. replace wires billymac
Jun 3, 2009 at 11:12 AM
JAY_89
  • 5 POSTS
thnx a lot
i just talked to the dealer from i bought the car and he said he hvnt change the wires or transmission filter
so shld i go for transmission service ??
Jun 3, 2009 at 11:20 AM
BILLYMAC
  • 2,204 POSTS
Hi yes i would service the trans and tune up atleast then you will know when it was done last
Jun 3, 2009 at 11:26 AM
JAY_89
  • 5 POSTS
and if the torque converter or solenoid are bad does they show code on computer or not ??
Jun 3, 2009 at 11:53 AM
BILLYMAC
  • 2,204 POSTS
Hi yes this will store a code for tcc. a trans shop would have caught that
Jun 3, 2009 at 12:35 PM
