1998 Chevy Lumina I have a question about struts/shocks
115,000 MILES • 6 CYL • FWD • AUTOMATIC
GAVINSMOM05
I have a noise coming from the rear of my car when I go over bumps - it's a squeaking noise that is worse when the bumps are bigger. (Sounds like a squeaky spring when it coils and recoils when compressed and let go.) I have been told that it could be the struts, the bearings, bushings, inserts, etc.
There is also a new rattling noise that happens when I go over bumps as well. It's not very loud, but it's there and I can't pinpoint exactly where it's coming from.
What do you think?
Nov 19, 2008 at 2:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Rattling noise is possible broken exhaust hanger. Exhaust is probably rattling around a bit. As for the rear suspension, it COULD be any of those things you mentioned. The only way to find out for sure is to have a suspension shop check it out for you if it is bothering you a lot. However, worn suspension parts can cause premature tire tread wear so I would advise having it checked out as soon as possible.
Nov 19, 2008 at 5:01 PM
