1998 Chevy Lumina engine
1998 CHEVROLET LUMINA
200,000 MILES • V8 • 2WD • AUTOMATIC
TITLEMAN
The intake gaseskate is licking water into the oil what should I do for a quick fix or to fix it for good.
Dec 28, 2009 at 11:57 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Well, if you are sure it is the Intake Gasket then a good permenant fix, well probably not permenant fix, would be to replace the gasket. A temp fix you can try some stop leak.
Dec 29, 2009 at 12:44 AM
