1998 Chevy Lumina egr
1998 CHEVROLET LUMINA
180,000 MILES • 6 CYL • FWD • AUTOMATIC
BILL1806
I found what appears to be a water and oil mixture getting to the EGR valve. It is thick and pale in color kind of like grease. What is this and what is causing it.
Feb 20, 2008 at 11:53 AM
BMRFIXIT
  • 19,053 POSTS
[quote:71870fec7e="bill1806"]1998 Chevy Lumina 6 cyl Front Wheel Drive Automatic 180000 miles
I found what appears to be a water and oil mixture getting to the EGR valve. It is thick and pale in color kind of like grease. What is this and what is causing it.[/quote:71870fec7e]
check the intake manifold
Feb 20, 2008 at 11:57 AM
DENNYP
  • 1,824 POSTS
Leaking lower intake manifold gaskets will cause this. Also, a bad throttle body gasket can cause it. Some of the throttle bodies have coolant passages that are sealed by this gasket.
Feb 21, 2008 at 12:49 PM
