1998 Chevy Lumina DOME LIGHT
RFITZ962
Electrical problem
1998 Chevy Lumina 6 cyl Two Wheel Drive Automatic
DOME LIGHT ON MY 1998 LUMINA STAYS ON ALL THE TIME. I UNDERSTAND IT COULD BE A DOOR SENSOR. WHERE IS IT?
Jun 14, 2008 at 7:09 AM
BLACKOP555
  • 10,386 POSTS
is the door ajar light on? does it come on when you open up the door with car running?
if so then its not the switch causing the problem.
they are in the coor jamb area.
is the switch for the instruument cluster lights turned all the way up and past the mark that clicks? turn it down all the way and see if it turns off.
Jun 14, 2008 at 9:53 AM
