Crankshaft pulley out of alignment
1998 CHEVROLET LUMINA
MLEGGETT2
Six cylinder front wheel drive automatic 152,000 miles.
Three weeks ago my serpentine belt broke on my 3.1 liter engine . I replaced it, and yesterday it broke again. I replaced the belt and the tension-er, and noticed that the crankshaft pulley appears to be out of alignment with the other pulleys; a third of the belt hangs of the inside of the pulley as if the pulley has moved outward from the engine.
Is it possible the the crankshaft pulley has moved? And do I fix this?
Jul 15, 2009 at 7:04 AM
JGBTTW
You are not crazy mleggett2, my son's 1997 Lumina has done the exact same thing and he has 146,000 miles. Question is for the experts, how did four other pulleys move simultaneously one way and stay perfectly in line and the crank pulley move the other way? Something is going on here. If anyone with some real knowledge about this problem knows what the problem is, I would welcome their response, otherwise I can sit here and guess with the best of them. Thanks
Feb 12, 2011 at 7:06 AM
MLEGGETT2
Turned out to be a worn out harmonic balancer. I had it replaced (sorry, I do not remember what it cost), and it works great.
Here is a guide to help I found on this site:
https://www.2carpros.com/articles/how-a-harmonic-balancer-works
Saved me a bunch of money.
Feb 12, 2011 at 7:15 AM
  • 110,244 POSTS
Yes, this happens all the time.
Please use 2CarPros anytime, we are here to help. Tell a friend please.
Cheers
Feb 12, 2011 at 1:10 PM
SURPRISEFARMS
This exact same problem just happened to me over this last weekend so to clarify even further on Jacobandnickolas last response. The pulley is not the part that moved, the harmonic balancer actually separated from the pulley and then moved outward. The balancer and pulley come new as one unit however the balancer is simply fused to the pulley with a rubber material and only looks like a one-piece “solid steel” unit. In my case the rubber deteriorated over time allowing the balancer to move freely from the pulley.
Feb 28, 2011 at 12:59 PM
ROBERT O KLINE
My 2000 GMC Safari van 2 wheel drive 114,000 miles got ice between the bottom pulley last winter and broke the serpentine belt (i'm just now getting around to replacing that) The issue is the belt runs 3 groves towards the radiator after 3 times releasing tension and making sure it's seated but as soon as you crank the engine and starts, it jumps over - - all the others (Alt, Ac, PS) stay in their groves.
Jul 4, 2019 at 7:58 AM
  • 55,423 POSTS
Excellent addition to this thread! Please feel free to help out whenever you are on the site :)
Jul 7, 2019 at 10:52 AM
