Engine Cooling problem
1998 Chevy Lumina 6 cyl Two Wheel Drive Automatic
coolant leak coming from evaporator drain tube on the firewall does the heater core have to be replaced heater blowing cold air not leaking inside the car. changed thermostat didn't help
car is now over heating. i have to replace the radiator lot of slug in the system can the system be flushed before i put new parts on.
May 25, 2009 at 3:52 PM
