1998 Chevy Lumina COMPRESSOR CLUTCH WONT ENGAGE
1998 CHEVROLET LUMINA
MECHANICASE
  • 5 POSTS
Air Conditioning problem
1998 Chevy Lumina 6 cyl Two Wheel Drive Automatic
I HAVE BEEN WAITING FOR 4 HOURS FOR AN ANSWER TO MY QUESTION.....IS ANYBODY HOME??????? I'VE ALREADY DONATED $15.00 STILL WAITING FOR AN ANSWER.........
Feb 13, 2009 at 2:54 PM
Does it have freon in it? No freon it won't engage or possible the magnetic clutch is locked-up
The most likely cause of an automotive air conditioner cooling problem is no refrigerant in the system. If the refrigerant has escaped past a leaky compressor or O-ring seal, leaked out of a pinhole in the evaporator or condenser, or seeped out through a leaky hose, the leak needs to be identified and repaired before the system is recharged.
On many systems, the compressor will not turn on if the refrigerant is low because the "low pressure safety switch" prevents the compressor clutch from engaging if system pressure is low. This protects the compressor from possible damage caused by a lack of lubrication.
One of the first things you should check, therefore, is compressor engagement. If the compressors magnetic clutch is not engaging when the A/C is turned on, the problem may be a blown fuse or a wiring problem. If the fuse is blown, replacing it may restore cooling temporarily. But the underlying reason for the fuse blowing in the first place needs to be identified and corrected to prevent the same thing from happening again.
If the magnetic clutch is receiving voltage but is not engaging the compressor, the clutch is defective and needs to be replaced. If there is any evidence of leakage around the compressor shaft seal, the seal should also be replaced.
If the clutch works but fails to turn the compressor (the belt may squeal in protest!), the compressor has seized and needs to be replaced.
Compressor failures are usually the result of loss of lubrication, which in turn may be due to low refrigerant in the system, a blockage (such as a plugged orifice tube which prevents refrigerant and oil from circulating to the compressor), loss of lubricant due to leaks or improper service procedures (not adding oil to the system to compensate for oil lost through leakage or component replacement), or use of the wrong type of lubricant.
Feb 13, 2009 at 3:13 PM
