1998 Chevy Lumina Changed Brakes but now they dont work?
145,000 MILES • 6 CYL • FWD • AUTOMATIC
ALLFORLIFE85
Ok i have a 98 chevy lumina. I just replaced the brakes today, and took it for a test drive, but once doing so i have to push the brake pedal all the way down, and that still didnt make the brakes work??? So if u have any ideas on how to fix this problem or let me know what is causing this to happen that would be great thx's
Mar 25, 2008 at 7:08 AM
BMRFIXIT
  • 19,053 POSTS
Don’t put your self and the surrounding drivers in danger!!!!
you should have it check by a qualified personal
you may :
check master cylinder
do u have an ABS
check rear brakes
check for fluid leaks
check for air in the system
Mar 27, 2008 at 10:28 AM
