1998 Chevy Lumina Burning or Leaking Oil
1998 CHEVROLET LUMINA
FUFUNINA
Transmission problem
1998 Chevy Lumina 6 cyl All Wheel Drive Automatic
Hi, my name is Michelle and I am wondering why in the past couple of weeks, I have been having to put a quart of oil in my Lumina about every four days. I brought it to a friend who is a mechanic, and he doesn't seem to think there is anything wrong with it. He said that I needed a water pump instead. Is there any relationship between these parts, and if you have any suggestions I would truly appreciate it. Happy New Year and I hope to hear back from you soon.
Michelle[img:aadf4602df]http://www.2carpros.com/forum/automotive_pictures/457739_121aa919fb2f__1217931457000_1.jpg[/img:aadf4602df]
Jan 3, 2010 at 7:25 AM
  • 110,240 POSTS
Michelle:
Are you leaking coolant? Honestly, there is no connection between the two unless you have a bad head gasket. Your mechanic friend should recognize that because oil and coolant usually end up mixing in the engine or radiator.
As far as a quart every 4 days, that sounds like a lot. How many miles do you drive in 4 days? Do you ever smell something burning? Have you ever noticed oil on the ground where you park?
Jan 19, 2010 at 5:04 AM
