1998 Chevy Lumina brake/turn signal lights
JJOSHIN2
Electrical problem
1998 Chevy Lumina 6 cyl Front Wheel Drive Automatic
Hi, Recently tried helping my sister-in-law with a used car she purchased.Originally it appeared as if a few lights were out,but after relacing all and others that were still working,found that brake lights on rear end wont work on their own,but rear dash brake light will.also have what i believe the turn signal switch is bad,as operating it can either work right,or cause fast operation,or not work at all depending on which way you push-pull or giggle turn signal handle. Im leaning toward the switch but not sure how it ties through with the brakes
Dec 6, 2009 at 2:35 PM
  • 75,988 POSTS
Get the turn/hazard switch tested everything goes thru there before it hits the back
Dec 6, 2009 at 3:41 PM
CHANTW0968
[quote:10d9f701f1="jjoshin2"]Electrical problem
Hi, Recently tried helping my sister-in-law with a used car she purchased.Originally it appeared as if a few lights were out,but after relacing all and others that were still working,found that brake lights on rear end wont work on their own,but rear dash brake light will.also have what i believe the turn signal switch is bad,as operating it can either work right,or cause fast operation,or not work at all depending on which way you push-pull or giggle turn signal handle. Im leaning toward the switch but not sure how it ties through with the brakes[/quote:10d9f701f1]
I'm not a mechanic, but this very same thing happend to my car and after researching it. I found out that its very common for this to happen. What happend with my car was that the break light did not work and only the third light worked. I had to have a mechanic replace the turn signal switch to fix the problem.
Dec 13, 2009 at 11:31 AM
  • 75,988 POSTS
Its always like that when the top works but bottom don't-turn/hazard switch
Dec 13, 2009 at 11:35 AM
