1998 Chevy Lumina brakes going to floor
JEANAG
Brakes problem
1998 Chevy Lumina 6 cyl Front Wheel Drive Automatic
when I apply my brakes the car stops but if I hold the pedal down it goes slowly to the floor. before this happened my anti lock break light would come on and go off at different times.
Sep 17, 2009 at 10:30 AM
BMRFIXIT
  • 19,053 POSTS
Check brake fluid
if low add and check for leak
in the brake line
if full and no leaks suspect bad master cylinder
Sep 17, 2009 at 11:09 AM
