1998 Chevy Lumina antilock pulsing/ Brake performance not e
65,000 MILES • 6 CYL • FWD • AUTOMATIC
PONCHODUDE
Hello, I have a problem with my antilock brakes. When coming to a stop, you can hear the anti lock motors or motor pulse several times. Sometimes three or eight times. I can tell especially in the dark because the headlights will dim slightly as you hear the pulsing.This happens below 30 mph and there are no warning indications on when this is happening. I have checked all the connections at all four wheel sensors by removing & reinstalling the connectors. I have also done this where the connectors come out of the floor pan & run to the rear wheel sensors. I also located the ABS control module under the dash and pushed connectors but did not remove them. Was wondering if my only last choice was to get it scanned or not. I did not know since there are no fault lights associated. Thank You..
Oct 29, 2009 at 12:10 PM
  • 110,244 POSTS
If there isn't a light, chances are there will be no code. On the other hand, you need to start somewhere. I would try having the computer scanned at a nationally recognized parts store. Most will do it for free.
If that doesn't help, I have a feeling there is something that a sensor is identifying as a wheel stopping. Make sure everything is clean. You may end up at a dealer to have it checked with proper equipment.
Nov 16, 2009 at 12:16 AM
