the front (clutch) bearing seems to be bad, making a lot of noise and pulls hard on belt. how do you replace it?
Feb 27, 2008 at 10:50 PM
MERLIN2021
✓Experienced Mechanic
On newer types, go to the junkyard, because aftermarket bearing and pulley will not fit,unless you swap the coil too, pick out a good used compressor, and if yours still works, just swap the pulley....wont even need to open the system, usually a 8mm screw holds the clutch face on, then a snapring hold the pulley...be sure you put the snap ring on facing the same way it came off the old one!
