1998 Chevy Lumina
HARLEYBOOTS442
Engine Mechanical problem
1998 Chevy Lumina 6 cyl Two Wheel Drive Automatic 170.00 miles
ok this is what i did. i did a head job all went well but i was cleaning the lifters a one was stuck so i took everyone apart & cleaned them. dont worry all push rods lifters & rockers went back to were thay origianl place. so any how when i cleaned all the lifters then i soaked them in oil for 24hrs put the engine back togather & thghtin all bolts to spec now the engine sounds like a deisel what did i do wrong?
Sep 25, 2010 at 8:34 AM
MERLIN2021
  • 17,250 POSTS
Check the timing it sounds like the chain is off by a tooth or two, is it low power? Check the compression, if it's a bit low, recheck your timing. The other possibility is if the timing is good, check the oil pressure, it could be low. Top ends is the last to get oil...
Sep 25, 2010 at 12:04 PM
