1997 lumina, 3.1 L 89,600 miles
WSWJONES08
  • 38 POSTS
Ahhh yes, another problem with my wonderful car. I have a noise coming from the left tire. Its not a clicking or humming. It does it when the tire is moving, and sounds like a scraping. It doesn't do this at low speeds, usually 25mph+. The car also has been vibrating around 50 mph. Bad wheel bearing maybe?? All help is appreciated.
Nov 2, 2007 at 2:18 PM
MERLIN2021
  • 17,250 POSTS
Wheel bearings will growl when you get to about 30-35 mph and higher, the sound can be tested by steering left and right, if the noise diminishes or goes away when turning, and comes back when you go straight, it's a bearing...the noise only goes away turning 1 way!
Nov 3, 2007 at 12:06 AM
WSWJONES08
  • 38 POSTS
i lied, its not so much of a scraping now that i think of it... i couldnt think of the word before but its more of a squeaking. its coming from the front left tire and it does seem to stop/quiet down when i turn.
Nov 3, 2007 at 6:58 AM
MERLIN2021
  • 17,250 POSTS
Pull the tire off and check the pads! there is a tang built on to them to warn of low lining condition!
Nov 3, 2007 at 8:10 AM
