1997 Chevy Lumina won't strat
1997 CHEVROLET LUMINA
92,000 MILES • 6 CYL • FWD • AUTOMATIC
TCMITCHMAINE
my chevy lumina won't start i turn the key and nothing. have tried to boost batt., checked all fuses,charged batt.. I have crossed the terminals on the starter and it cranks that way. I was told it was the key and the dealer told me it probably isn't that i should have the codes checked. all lights work and all guages work have tried it in neutral as well and it still won'tstart, any ideas?
Feb 28, 2010 at 11:11 PM
LEGITIMATE007
  • 5,121 POSTS
try putting it in neutral and starting it. I also suspect the wiring is loose or disconected,
Feb 28, 2010 at 11:25 PM
LEGITIMATE007
  • 5,121 POSTS
check wiring from battery to alternator to starter for signs of corrosion inside the protection layer of each wire
Feb 28, 2010 at 11:26 PM
