Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Lumina
Brakes
ABS
Wheel Speed Sensor
Location
1997 Chevy Lumina wheel speed sensor
1997 CHEVROLET LUMINA
140,000 MILES • 6 CYL • FWD • AUTOMATIC
SILVERADOMAN5
MEMBER
1 POST
Where is the wheel speed sensor located on this model car. Is there one for each wheel and if so how do you determine which one is bad?
May 5, 2008 at 11:06 AM
BLACKOP555
Experienced Mechanic
there is one on each wheel, you will see a "gear" at the back of the hub, the abs speed sensor gets data off of that gear.
to check them hook up a multimeter to it and turn the wheel, it should read voltage, then check for resistance and make sure its withiin specs.
May 5, 2008 at 12:28 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
