1997 Chevy Lumina wheel speed sensor
140,000 MILES • 6 CYL • FWD • AUTOMATIC
SILVERADOMAN5
Where is the wheel speed sensor located on this model car. Is there one for each wheel and if so how do you determine which one is bad?
May 5, 2008 at 11:06 AM
BLACKOP555
  • 10,386 POSTS
there is one on each wheel, you will see a "gear" at the back of the hub, the abs speed sensor gets data off of that gear.
to check them hook up a multimeter to it and turn the wheel, it should read voltage, then check for resistance and make sure its withiin specs.
May 5, 2008 at 12:28 PM
