1997 Chevy Lumina turn signal
1997 CHEVROLET LUMINA
81,000 MILES • 6 CYL • FWD • AUTOMATIC
JPTRUCK
no turn signal. fuses are all good. where is the flasher located for the turn signals. the 4 way flashers work good...but no turn signals!! please help
Jan 24, 2009 at 1:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Test flasher relay. Flasher relay is located behind dash, right of steering column. For information on testing relays, follow the link below:
https://www.2carpros.com/how_to/how_do_i_check_a_relay.htm
Post results and I will follow up.
Thanks for using 2CarPros.com!
Jan 24, 2009 at 1:38 PM
