1997 Chevy Lumina Starting and Acceleration Problems
135,000 MILES • 6 CYL • FWD • AUTOMATIC
GIXXER169
I recently bought a 97 lumina 3.1V6 and after a couple weeks now, when i try starting the car it turns over like it's going to start but doesn't, if i turn the key off and right back to start, most of the time it cranks with no hesitation. (sometimes a third time is required). When i go to crank it though if i just turn the ignition on for a few seconds and repeat a couple times then it will start right up so i doubt it's anything to do with my starter. I've replaced the plugs, wires, fuel filter, and now have a fuel pump ordered. I'm really not sure as to where to go from here if pump doesn't work. Also for a week now, sometimes when i accelerate it acts like im barely pressing the gas, doesnt matter if i have the pedal all the way down or not, then after a little while it starts accelerating just fine.
Mar 25, 2010 at 8:25 AM
  • 75,988 POSTS
Hi gixxer169, Welcome to 2carpros and TY for the donation
Check the fuel pressure if its within specs both KOEO and KOER if okay check and test the throttle position and manifold absolute pressure sensors.
Mar 25, 2010 at 10:48 AM
GIXXER169
thanks for your quick responce, how would i go about checking the TPS and manifold sensors? Is this something i can do at home or will it need to go to a shop?
Mar 26, 2010 at 8:49 PM
  • 75,988 POSTS
Yes if you have a digital volt/ohmmeter-do you and know how to use it If not I recommend you go ahead and bring it-
Mar 26, 2010 at 10:20 PM
