1997 Chevy Lumina sluggish on take off
140,000 MILES • 6 CYL • FWD • AUTOMATIC
WES987654321
when i push on the gas to go the engine revs but the car is extremely slow to take off and it consumes a large amount of gas
Jul 10, 2010 at 2:24 PM
  • 75,988 POSTS
If the transmission is not slipping-see below:
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jul 10, 2010 at 2:46 PM
