1997 Chevy Lumina Radiator Fan runs when car is off but won
1997 CHEVROLET LUMINA
150,000 MILES • 6 CYL • FWD • AUTOMATIC
BARBIMATHISEN
The starter was replaced in the car and immediately afterward the fan started running while the car is off. We pulled the radiator fan relay sensor which stopped the fan and the car started but if the fan is running, the car will not start. If we replace the sensor while the car is running, when the car gets hot enough for the fan to kick in, the car shuts off. The car will also shut off if we turn on the a/c. We replaced the radiator fan relay sensor but this did not fix the problem. Help!!
Mar 29, 2010 at 4:52 PM
LEGITIMATE007
  • 5,121 POSTS
does this vehicle have two fans?
Mar 30, 2010 at 1:42 AM
LEGITIMATE007
  • 5,121 POSTS
check the engine coolant temperature sensor as well
Mar 30, 2010 at 1:43 AM
LEGITIMATE007
  • 5,121 POSTS
I think you may have several problems going on at once. idle air control valve also becuase when you turn the a/c on the engine shuts off correct. well the idle is supposed to be raised when you turn the a/c on so that the car doesnt shut off, and the IAC, is what controls your idle
Mar 30, 2010 at 1:44 AM
BARBIMATHISEN
We are going to replace the engine coolant temperature sensor today (unless it starts pouring rain again). I'll let you know how it turns out. Thank you for your response!
Mar 31, 2010 at 2:01 AM
LEGITIMATE007
  • 5,121 POSTS
hey, no problem, keep me posted, by the way, you said rain, Im wondering if you are near me, we had rain for three days, its supposed to be nice tomorrow however
Mar 31, 2010 at 2:42 AM
