The starter was replaced in the car and immediately afterward the fan started running while the car is off. We pulled the radiator fan relay sensor which stopped the fan and the car started but if the fan is running, the car will not start. If we replace the sensor while the car is running, when the car gets hot enough for the fan to kick in, the car shuts off. The car will also shut off if we turn on the a/c. We replaced the radiator fan relay sensor but this did not fix the problem. Help!!
Mar 29, 2010 at 4:52 PM
