1997 Chevy Lumina Power Steering Pump
20,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIKE DUGAN
How do I remove and install new power steering pump on a 1997 Chev Lumina 6 cylinder 3.1
Feb 12, 2008 at 9:40 AM
MASTERTECHTIM
  • 4,750 POSTS
first of all before starting the job you will need a pulley remover to press the pulley off the pump. if you are using a used pump and it has the pulley already on it then just remove the 3 thirteen mm bolts holding it on then remove the 15 mm nut holding the lines secure. remove and replace.
Feb 12, 2008 at 9:42 AM
