1997 Chevy Lumina No spark form coil packs after intake gas
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
BHUDSON97
I replaced the lower intake gasket on my 97 Lumina ltz and after putting it all back together I get no spark from the coil packs. What could I have missed to make it do this? I also hooked up the battery with everything unhooked to check for fuel line leaks before I put the rest of the motor back together could that have screwed somthing up?
Dec 1, 2008 at 6:21 AM
  • 110,246 POSTS
Hi:
Make sure you didn't accidently unplug the crank or cam sensor.
Dec 3, 2008 at 7:01 AM
