1997 Chevy Lumina No spark
99,000 MILES • 6 CYL • FWD • AUTOMATIC
CAMAROZ28LT4
Well we rebuilt the engine because it spun a bearing, and go to start it, and it just cranks, pulled a plug and it looks like there is no spark. It is a 3.1 v6. I have no clue what could be the problem, Thanks.
Dec 11, 2007 at 5:05 PM
JEFFYTUNE
  • 12 POSTS
Hi.
Question......
Did you plug in the crank sensor?
It's easy to miss, it is a two wire sensor on the Right side of the engine(If your looking at the front of the engine)
These sensors are also well known for failure.
If you have a DSO, check the pattern out of the sensor.
If not, just pull it out and look it over for cracks or the pins broken.
If all else fails, try a new sensor.
Jeff m.
Dec 11, 2007 at 6:13 PM
