The air conditioner/heating system is stuck on bi-level. I can change the temperature and the fan speed, but not how the air is coming out. It is always on defrost and feet (bi-level). I was told the problem is probably the mode door actuator, so I bought the part and attempted to remove the instrument panel carrier. I was able to remove everything until it came to the last step (#24) in the repair manual, which was to remove the instrument panel from the vehicle carrier. I just could not figure out how it was held in place. There may have been some clips up near the windshield, but was not sure. I am on the right track to replace the mode door actuator to repair the problem? if yes, how do I remove the instrument panel form the vehicle carrier?
Jun 12, 2010 at 3:16 PM
