1997 Chevy Lumina Lights inside go out
1997 CHEVROLET LUMINA
36,000 MILES • 6 CYL • 4WD • AUTOMATIC
KELANDI
I bought my lumina about a month ago. Low mileage, in great condition. I love it, it drives great. The check engine light was on when I bought it but had a machanic glance at engine, he fixed some wire and said he just needed to reset. (Did this outside of work so I need to go back to reset.)
About 2 weeks after I bought car, I was driving at night and inside dash lights went out. I got them back on by turning the lights off of auto. Happened again 2 weeks later. Then a week ago the right blinker light inside stopped working. Outside blinker works. Low coolant light flashes some days and so does low track. Any suggestions?
Also trying to get a picture of where low intake valve is so I can add some 134A.
Thanks,
Diane
Jul 9, 2008 at 2:48 PM
2CARPRO JACK
  • 11,533 POSTS
Since the light problems all revolve around the cluster, it may have a bad ground or connection in the main plug/plugs. The low side of the a/c is the larger line that goes from the compressor to the inside of the car, low side fitting is on that line somewhere, may even be on the accumulator/receiver-dryer which is a big silver cylinder that the low side lines hook to
Jul 11, 2008 at 12:23 AM
