i put a fuel pump in and i got it started once and i shut it off to fix the vacumm hose and it would not start again
Dec 26, 2007 at 6:57 PM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
CAR REPAIR CONTRIBUTOR
When you turn key to On position do you hear the fuel pump come On for 2 secs? If so check the actual fuel pressure with a gauge and come back with the readings.
