1997 Chevy Lumina front hub bearing replacement
60,000 MILES • 6 CYL • FWD • AUTOMATIC
STREAMROCK
front driver side wheel bearing bad. trying to replace. cannot get bearing assembly out. removed all bolts-4. see no other way fastened. have hub puller. does not come off. very rusty. how can i remove hub bearing assembly? cannot remove knuckle to try to press out--sorry, no picture.
May 10, 2010 at 3:57 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating You could try heating it since it is rusty. This will cause the metal to expand and possibly loosen it up a bit. The replacement steps are below so be sure you have completed all steps as well..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2139.jpg
May 10, 2010 at 5:10 PM
STREAMROCK
is it okay to use a pneumatic impact wrench on hub puller to provide more torque in pulling assembly out? Or would that vibration cause damage to cv joint?
May 11, 2010 at 10:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
many people do like using impact wrenches on pullers, but sometimes this can do more harm than good so i wouldn't recommend it. the whole point of a puller is so you won't have to use a hammer, impact wrench or anything that could do damage to the cv axle or other nearby parts.
May 11, 2010 at 11:05 AM
