1997 Chevy Lumina Evaporate System Monitor Reset
210,000 MILES • 6 CYL • 2WD • AUTOMATIC
DYUHELP
I have a 97 Chevy Lumina and I had some trouble
codes show up and replace the appropriate parts.
Now I am waiting for the computer to reset itself
to show ready for the systems it checks. What does
it take to get the computer to completely reset
itself? I have check the system with a scanner about
every other day and it still hasn't completely reset yet. I am still waiting for the evaporation system and EGR to reset. I need to get the car to pass the emission check so I can get the license renewed.
Feb 20, 2009 at 3:32 AM
  • 110,248 POSTS
Hi:
Either disconnect the battery for about 5 minutes or I believe you can reset it with the scanner.
Feb 20, 2009 at 9:33 AM
DYUHELP
As I said in my original, I have scanner and it will clear the codes. What I need to know is after the codes
are cleared how many miles, how many starts, or whatever does it takes before the system will show ready. I cleared the codes last week and now all the system show ready except the EGR and EVAP systems. I need to know what does it takes to get them to show ready when I check them with my scanner. I can't pass the emission test until they
are in the ready mode.
Feb 21, 2009 at 2:45 AM
  • 110,248 POSTS
Normally between 100 and 150 miles should do it. It's all based on cycles, but normally that many miles should do it.
Feb 21, 2009 at 5:13 AM
DYUHELP
The Lumina has been driven at least 300 miles and the EVAP and EGR system are still not ready. Do you have any idea how many cycles it takes? I assume a
cycle is a engine start and then turned off. Would a
inoperative gas gage keep the EVAP system from being Ready. I think it the sending unit in the tank
that broke.
Feb 23, 2009 at 2:02 AM
  • 110,248 POSTS
A bad fuel cap will keep the evap light going. If the sending unit is bad and leaking, it could do the same. Finally, a cycle is based on many things, not just start-up. It is determined on driving conditions, speed, eng temp... Regardless, 300 miles should have done it.
Feb 23, 2009 at 7:23 AM
