1997 Chevy Lumina driver side window
113,000 MILES • 6 CYL • FWD • AUTOMATIC
CHOPPER100
i put my driver power window down and i can't get it to go back up i took the door panel off and checked the fuse box they where all ok then i went to take the plate that the motor is on and i hit the power button the window went down the plate that holds the motor moved and i can't move it back i took the screws out like a dumy so what can i do to take the pressure off and line that plate to screw it back
Jan 29, 2010 at 2:56 AM
ERNEST CLARK
  • 1,730 POSTS
You can disconnect the two screw that holds the glass to the regulator, then remove the motor from the regulator bracket.
This will allow you to move the mechanism up and down so you can fit it back in place. Then do the reverse to reinstall it.
As for your switch, you probably have a bad contact in the switch or one of your wires is broken.
If you know how to use a test light, you can probe the switch and wires util you find the problem. If not, then you'll have to find someone who can.
I recommend going to your local community college and finding a student. They'll certainly do this for cheaper than a shop.
Feb 8, 2010 at 12:41 PM
