1997 Chevy Lumina brake lights
NOOK7477
Brakes problem
1997 Chevy Lumina 6 cyl Front Wheel Drive Automatic
the brake lights on my car dosen,t work unless I TURN ON MY PARK LIGHTS,but when I turn on my signal light they go off,what,s the problem.
Loretta
Jan 18, 2010 at 4:40 AM
JDL
  • 16,098 POSTS
welcome to the forum. Does the high-mount brake lite work? If it doesn't, I'd have to check the brake lamp switch. To find the switch, you follow the brake pedal arm upward. Check fuse 23--15 amp.
Jan 18, 2010 at 4:49 AM
