1997 Chevy Lumina brake lights
LEN019
Electrical problem
1997 Chevy Lumina 6 cyl Front Wheel Drive Automatic
Tail lights work fine. Brake lights do not come on. The brake light in rear window comes on. Right side turn signals, front and back work. Left side in rear does not work. Left side in front flashes real fast. When you turn the brights on the brake lights work and all four turn signals work fine. You can leave the turn signal on and click the lights back to low beam and the turn signals and brake lights still work. As soon as you turn the turn signal off it goes back to the initial problem.
Thanks for any help.
Dec 8, 2009 at 11:03 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check ALL bulbs as well as your fuses. also test flasher relay. if all are OK check brake lamp switch located on brake pedal bracket below driver dash.
Dec 9, 2009 at 6:27 AM
