1997 Chevy Lumina Brake Lights
RATERS_FAN
Electrical problem
1997 Chevy Lumina 6 cyl Front Wheel Drive Automatic
How would I fix it so my brake lights work? There are new bulbs and we've figured out it is the wiring in the directional that is causing the brake lights to not work.
Feb 10, 2009 at 1:34 AM
DOCFIXIT
  • 18,828 POSTS
Have ou checked the brake switch on pedal?
Feb 10, 2009 at 2:27 AM
RATERS_FAN
No I did not, to be perfectly honest, I do not know exactly what to look for by the brake pedal. I also found out that this is a generic problem for all Chevy Lumina Sedans.
Feb 10, 2009 at 2:40 AM
DOCFIXIT
  • 18,828 POSTS
Up on pedal towards top there is a button switch when pedal is pressed switch closes turning lights on.
It maybe stuck or faulty if you pull terminal off jumper with paper clip lights should come on. Let me know
Feb 10, 2009 at 2:49 AM
RATERS_FAN
I just went out and looked underneath by where the brake pedal is. I did not see a switch. It may be way up inside. There is material covering up that area.
Feb 10, 2009 at 2:58 AM
