1997 Chevy Lumina backlighting on gauges
240,000 MILES • 6 CYL • FWD • AUTOMATIC
CLARKB16
I recently had my backlighting stop woring on my guages. I checked all the fuses and they seem fine. gauges and lighting from behind the heater and fan control swiches is not working but everything else works fine.
Mar 23, 2008 at 10:41 AM
MASTERTECHTIM
  • 4,750 POSTS
make sure the dimmer switch is not turned on low. also check the dash fuse, it should be a five amp fuse
Mar 23, 2008 at 10:52 AM
CLARKB16
where is this fuse located at? i looke at my main 3 fuse clusters and didnt see one for the dash or instrument panel. could it be behind the dash?
Mar 23, 2008 at 11:16 AM
