1997 Chevy Lumina 97 Chevy Lumina, 3.1
15,400 MILES • 6 CYL • FWD • AUTOMATIC
CHARLOTTE_N_MI
The problem started 2 weeks ago I would be driving and the acceleration would let up when my foot was still on the gas, but would only last for a few seconds and would start to accelerate again. I thought nothin of it and put some carb cleaner in it, and I seen I was a quart low on oil, so I also put that in. A short while later the car did it again and then it compleley died, at which time I tried to restart it and it will start after a 20-30 seconds of turning the key but it is very hard sounding, extremly loud, and if I dont stay on the gas pedal pumping it the car bogs out and dies, also if I try to put it in gear it dies. It sounds horrible, I don't hear a rod knock at all, and the car did not over heat. Is my motor junk, is it the timing chain, cadilac converter??? I'm so LOST
May 22, 2009 at 3:46 PM
  • 75,988 POSTS
Check the fuel pressure and comeback with the readings
May 22, 2009 at 3:50 PM
CHARLOTTE_N_MI
I had a compression test done and the readings were normal in some of the cylinders but running 10 in some, I think that is what you needed. Is that fuel pressure lol I am your average female that knows jack about cars
May 24, 2009 at 4:42 PM
  • 75,988 POSTS
Okay get some help on checking the fuel pressure and comeback with it I need this info before I can continue.
Or you can try cleaning out the idle air control valve and the EGR and PCV valves and see what happens.
May 24, 2009 at 9:38 PM
