1997 Chevy Lumina
124,000 MILES • 6 CYL • FWD • AUTOMATIC
BOBSWANK
my 97 lumina starter was replaced Feb. '10 reman lifetime warranty autozone. Now it cuts off in the middle of starting. All connections are tight and clean and battery is newer and fully charged. It does this occasionally typically every 7-9 attempts to start. Engine is running fine when started, and starts quickly and easily when starter is engaged. Is my starter in need of replacement? I read on your website about poor reman starter reliability. Thanks. This is daughter's car. I need it to be dependable for her.
Oct 11, 2010 at 1:11 AM
WRENCHTECH
  • 20,760 POSTS
What exactly is happening? Does it start and stall? Does the starter just quit cranking suddenly? Please give us a better description of what it's doing and how you eventually get it started.
Oct 11, 2010 at 1:44 AM
BOBSWANK
The starter just suddenly stops cranking. Each time after this I try to start it and it does the same thing. Then at times it will start like there is no problem. When it stops cranking there is a clattering noise briefly.
Oct 11, 2010 at 2:02 AM
WRENCHTECH
  • 20,760 POSTS
That does sound like a bad starter but would have to be tested during the failure to conclude anything.
Oct 11, 2010 at 2:04 AM
BOBSWANK
Are you of the opinion that reman starters with LLW are prone more to fail than original equipment, and/or do u know autozone's reputation for their duralast parts. I have had pretty good luck with duralast. Thanks Wrenchtech!! Bob Swank
Oct 11, 2010 at 2:07 AM
WRENCHTECH
  • 20,760 POSTS
Of course they are. That stuff is just Chinese made junk that is marketed well by giving a warranty. They don't care if they have to replace it a dozen times. They aren't the ones that perform the labor.
Oct 11, 2010 at 2:11 AM
BOBSWANK
Thanks wrenchtech for your prompt help and confirmation of my hunch about this starter. It is at least under warranty and I get another one free. This one on this lumina is easy to replace. Hope u get paid for this answer. I fully accept your consultation. Thanks again! Bob
Oct 11, 2010 at 2:17 AM
WRENCHTECH
  • 20,760 POSTS
Thank you
In the future, Delco brand is the way to go on GM vehicles.
We appreciate you leaving positive for me if you can.
Oct 11, 2010 at 2:20 AM
