1997 Chevy Lumina
L-WIZZLE
Engine Mechanical problem
1997 Chevy Lumina 6 cyl Front Wheel Drive Automatic
I HAVE A BLONE 97 3.1. I ALSO HAVE A 91 3.1 CAN I CHANGE EVERTHING OVER . ARE THE BLOCKS THE SAME.
May 27, 2010 at 7:05 PM
HMAC300
  • 48,601 POSTS
the only thing that will be different will be the brackets/ etc. change all that stuff from your newere engine on the older one. If you have a rear wheel drive one then it won't work becasue the starter is on the wrong side. So if it came from a truck or camaro it won't work.
May 30, 2010 at 7:28 AM
