1997 Chevy Lumina
DEDE_SLAUGHTER
Engine Mechanical problem 1997 Chevy Lumina 6 cyl Automatic My car started running hot so i changed th water pump, thermostat, and radiator. There is no water in the oil and wanted to know what else could it be.
Aug 14, 2009 at 2:33 AM
JDL
  • 16,098 POSTS
Hello, how do you know it is running hot? Any symptoms besides the temp gage? Is the recovery bottle overflowing? Does the radiator fan turn on? Before you replaced anything, did you check for coolant flow through the radiator?
Aug 14, 2009 at 3:47 AM
