1997 Chevy Lumina
LDAVIS
Electrical problem
1997 Chevy Lumina 16500 miles
Where is the turn signal flasher located?
Dec 24, 2007 at 3:30 AM
POET042005
  • 134 POSTS
I believe its in the steering wheel or on the steering wheel what type of problem are you having maybe I can help trace the problem.
Dec 31, 2007 at 9:02 AM
APOTTS01
The turn signal flasher is located to the left of the brake pedal. You will se a silver rectangular box that is strapped into place to the right and rear of this box is a square plug in that says "Combination flasher", this is the turn signal flasher.
Feb 8, 2008 at 5:28 AM
