1997 Chevy Lumina
210,000 MILES • 6 CYL • 2WD • AUTOMATIC
WILLARD60
a/c pump leak can i fix it with new seal or can i get a pump in junk yard to work tight on money new was 850.00 put in
Apr 30, 2009 at 1:32 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:5ba03b122c="willard60"]Air Conditioning problem
1997 Chevy Lumina 6 cyl Two Wheel Drive Automatic 210000 miles
a/c pump leak can i fix it with new seal or can i get a pump in junk yard to work tight on money new was 850.00 put in[/quote:5ba03b122c]
Were exactly is it leaking from? If leaking from seal were lines connect to back of compressor then yes you can fix it, you will just need to have system evacuated, unless system is already empty.
If leaking from front seal then special tools are need to replace that seal.
You can also call your local shops and ask for an estimate on repairing the leaking seal. Will be a lot cheaper than a compressor.
Apr 30, 2009 at 1:54 AM
