1997 Chevy Lumina
CHEVDOG
  • 1997 CHEVROLET LUMINA
  • 6 CYL
  • 130,000 MILES
How to change thermostat
Sunday, January 25th, 2009 AT 1:29 PM
  • 109,758 POSTS
Hi:
If you follow the upper radiator hose back to the engine, it will end at the t-stat housing. Drain the coolant from the radiator, remove the upper hose from the housing, remove the housing, remove the t-stat, clean the old gasket off, replace the t-stat, gasket and reverse the sequence.
Let me know if you have trouble.
Tuesday, January 27th, 2009 AT 7:24 PM
