1997 Chevy Lumina
200,750 MILES • 6 CYL • FWD • AUTOMATIC
INEEDANEWCAR
why is my car idling up and down then shut off i change the wires spark plugs and oil and map sensor the code maf or vaf come on but i went and got a use maf from a car that had a great engine it was brand new what can it be
Feb 16, 2009 at 4:39 AM
  • 110,248 POSTS
Has the check engine light come back on? Have you checked for vacuum leaks? The used MAF sensor you got, was it the same part number as the old one?
Feb 20, 2009 at 9:42 AM
