1996 Chevy Lumina Turn Signal
GABE119
Electrical problem
1996 Chevy Lumina 6 cyl Front Wheel Drive Automatic
The turn signal on the Lumina will not stay engaged when locked in place to make a left or right turn. However, if you just hold the handle just before the point of it being locked in place either way for auto shut off on the steering column, the turn signal will work. You just have to hold it in place just before it locks in to keep it blinking until you complete your turn. Is there a bad rocker switch on the steering column for the turn signal? What else would cause this problem and how do I fix it??? I appreciate any help you can offer. Thank you.
Gabe
Jan 28, 2010 at 10:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
suspect faulty turn signal (multi function) switch on steering column.
Jan 28, 2010 at 10:36 AM
