1996 Chevy Lumina thermostat
CCBLUME
  • 1996 CHEVROLET LUMINA
Engine Cooling problem
1996 Chevy Lumina 6 cyl Front Wheel Drive 180000 miles
how do I change the thermostat in this vehicle.
Sunday, February 8th, 2009 AT 2:25 PM
  • 109,867 POSTS
Follow the upper rad hose back to the engine. It will end at the thermostat housing. Drain the coolant, remove the upper hose from the housing, remove the bolts holding the theromstat, and the t-stat is under it. Reverse the sequence to replace.
Let me know if you have questions.
Friday, June 21st, 2019 AT 3:04 PM
