1996 Chevy Lumina Thermostat
SARAHCENTENO
Engine Cooling problem
1996 Chevy Lumina 6 cyl Automatic
I would like to know where the thermostat is located and can i get a diagram of its location? I sit difficult to change?
Mar 13, 2009 at 2:28 PM
TEAG
  • 158 POSTS
If your facing the car......look on the right for the big black radiator hose. Follow that to the engine. Thats where the thermostat is at. If you have a 3.8 youll need to remove the throttle body for easier access. Its an easy job. Just unbolt the thermostat housing (the part that the hose attaches to) and remove the thermostat. If you have the 3.8 start out by removing the air cleaner system and throttle body. If thats the case and you do have a 3.8......I can tell you step by step. Just repost that you have a 3.8. Its really easy though. Just taking out bolts and moving parts outta the way. Good luck. :)
Jun 21, 2019 at 8:05 AM
