1996 Chevy Lumina Tailights and dashboard lights not on whe
1996 CHEVROLET LUMINA
89,000 MILES • 6 CYL • FWD • AUTOMATIC
LP48322
My tailights and dashboard light are not turning on when the headlight switch is turned on. The dashboard light includes dashboard itself and at around the climate control and radio.
The bulbs are ok-at least in the taillights. The break lights do work.
The fuses seem ok too.
What else could cause both the dahsboard light and tailights not to come on when the headlight switch is turned on?
The brake/turning/headlights all work ok.
May 14, 2008 at 10:34 AM
MASTERTECHTIM
  • 4,750 POSTS
bad headlight switch or bad tail light fuse. check the brown wire at the headlight switch for power when turned on, if no power then the problem is the headlight switch.
May 14, 2008 at 10:58 AM
WSWJONES08
  • 38 POSTS
Check the contacts in the fuse box itself. Mine were corroded, so i had to cut the wires and connect it to a new fuse (holder? dont know what to call it). turn the headlights on, and then find the fuse (under the hood, drivers side) and wiggle it around. when you push it in a certain direction, the lights should work, hence it being corroded.
Jun 3, 2008 at 6:14 AM
